Automatic switching between debugger and power measurements
January 12, 2021
If you are performing power consumption measurements with Otii Arc and Otii Automation Toolbox and using a debugger in your everyday work, you may want to disconnect the debugger for every power measurement performed. The debugger can affect the power consumption measurements significantly. Yes, the manual task of switching off/on the debugger is however very annoying. That is why we have a solution for you to automated this unavoidable task.
We have prototyped a switchboard that you can use in your automation set-up to enable switching off/on the debugger or USB connection to your device under test automatically. The GPOs of the Otii Arc enable this automatic connect/disconnect function. You can connect your computer to your device under test, flash it, and then disconnect the computer from it again, by means of a simple script.
Below you find detailed instructions on how to use this switchboard.
Overview of the switchboard
Figure 1 Overview of the Switchboard
The left side 14-pin connector is intended to insert in Otii Arcs expansion port. All signals are passed through to the right side 14-pin header.
All power on the switchboard comes from Otii Arc +5V supply so this needs to be switched on to make it work. Switch it on, either via script or via UI.
Figure 2 UI control of +5V
Programmer interface
The programmer interface switches pin 1, 2, 4 and 10 of the 10-pin-header.
Figure 3 Programmer interface
Pin 3, 5 and 9 is connected to GND, pin 7 and 8 is not connected. The 10-pin header is both available as 2.54 pitch and 1.27 pitch (keyed).
The reason for choosing 1, 2, 4 and 10 is due to the ARM Cortex debug connector where VCC, SWDIO, SWDCLK and nRESET needs to be switched.
Figure 4 ARM Cortex debug connector
First, choose if GPO1 or GPO2 of Otii Arc is going to switch the relays. This is done with a jumper being either on the GPO1 or GPO2 side of the 3-pin header. A LED is lit when the relays are active.
USB interface
The USB interface switches D+, D-, VBUS and GND of the USB connector.
Figure 5 USB interface
It is a micro-B connector on one side and a type-A connector on the other.
First, choose if GPO1 or GPO2 of Otii is going to switch the relays. This is done with a jumper being either on the GPO1 or GPO2 side of the 3-pin header. A LED is lit when the relays are active.
Scripting
Use these commands to easily switch the relays:
Switch on +5V source on expansion port
device:enable_5v(enable)
Toggle GPO port on expansion port
device:set_gpo(port, enable)
Simple script turning on GPO1
local devices = otii.get_devices(“Arc”)
local box = otii.open_device(devices[1].id)
box:enable_5v(true)
box:set_gpo(1, true)
box:set_gpo(2, false)
Do you want to use the board?
Contact us if you are interested in the board or build a similar one yourself following the instructions from our customer Irnas, presented in their GitHub. Read more about how Irnas automate power consumption measurements.
